Surface Finish Issues On 12x36 (long Post) + Kb Electronics Vfd Install
"I have a suspicion based on personal experience....humor me? Please post a pix of the tool post and compound ."
To whom & what are you referring?
Jerry in Delaware
I believe he is referring to you and a pic of your tool post and compound slide as well. I'm pretty sure he is thinking that there might be a rigidity issue there. I don't personally see how a belt issue can cause a poor finish when your headstock is running true.
Sent from my LGLS991 using Tapatalk
Have you checked if the head stock to bed bolts are tight?
Yes, that was on my mind.. I had a finish similar to his when I installed a Chinese QC tool post. Found the bottom surface was not "flat" and when tightened down the actual load bearing area was right around the bolt. (imparting a microscopic rocking) Just ground off tiny amount of metal all around the bottom surface almost out to the edge, and it cured it immediately.
A couple of answers.
I have not checked the bolts, yet--very good thought--I will do that tomorrow.
About the QCTP--another excellent idea--I experienced that exact problem with a Phase II on my 9x20 several years ago and even wrote about it on the 9x20 forum. I used nearly the same procedure for the repair--I turned it in the 4-jaw instead of grinding.
Since is is past 10PM now, I'll check both of those things tomorrow, & report back.
Thanks,
Jerry in Delaware
On with the story.
This morning, I went to the shop & did some inspections.
1. Headstock bolts-----All tight.
2. Compound top surface---Not pristine, but not terrible, either-------Wrapped 600grit wet or dry around a large ceramic stone & polished (gently) the top surface.
3. QCTP bottom surface------really difficult to tell, so I placed a sheet of 600 wet or dry on my granite plate & a few drops of oil and gently rubbed the QCTP around (letting gravity do the downward pushing)---Wiped it frequently & continued till the bottom was about 90% shiny.
Tried another test cut on same material at the same speed/feed & with the same tool----NO CHANGE!
Repeated the test cut with the compound and the cross slide locked----NO CHANGE!
Next, I just let the machine run without the feed engaged---small vibrations evident (not huge, just a bit of vibration).
1. Checked the floor pads and made a tiny adjustment to one of them---very small improvement in the vibration.
2. Fussed with the floor pads till the minimum vibrations observed.
3. Removed the chuck & repeated the run listed above---still vibrating about the same.
4. Removed the drive belt & repeated---vibration gone. HMMMMM!!!
OK, I still haven't made a video. I am just about out of ideas.
Let me restate that the surface finish I am observing is not gross, or terrible. It is just not what I think it should be.
One more time---I am not terribly upset, PO'd, or any number of negative things--I just am hoping to get it all squared away.
I think I will just stop for a while & cut the grass.
Jerry in Delaware
Jerry, thanks for letting us all know how it is going and I am interested to find out what it is that is causing your issues.
Hoping for a simple fix but I am personally out of ideas.
Well, I'm not sure if they will be of any benefit; however, here are three short videos of the 12x36. Attempting to create these has given me an increased appreciation of what guys like Abom & K. Fenner & others do on a regular basis.
Just for reference: spindle speed = 700. Feed rate = 0.002. DOC = 0.005. Insert = TCGT. Material = 6061 @ approx 11/16 diameter.
Be Gentle, now.
Jerry In Delaware
  • M2U00032.mp4
  • M2U00033.mp4
  • M2U00035.mp4
I guess (in retrospect) I should have left the camera run after the cut was finished in the 2nd video. It looks exactly like it does before the cut started.
Jerry in Delaware
