- Mar 14, 2013
- 736
Got the new pot last night,I didn't do nothing till today. I had to walk away from this thing for a while.
I did ohm meter both pots, could only seem to get good contact (proper reading) some of the time.
But then again there was still solder in the contacts and I couldn't find my alligator test clips.
New one seemed to read proper, so I hooked it up.
Now, here we go again!!
this one is working to the correct direction, but still "touchy" esp. toward the Higher HZ.
But here is the thing, it works weather 11 is hooked up or not. I only have 9 hooked up, to one of the outside terms. on the pot.
There is a perimeter, AIN + - I think it was, switching that from 000 to 001 changes the direction the pot works in.
But it's still funny the # 11 outside wire does nothing.
I wish there was somewhere to buy another pot *Locally* to try besides radio shack.
I am gonna look for my test clips and check these pots better, unless there is something wrong with my inverter.
OK, I'll check it out, and report back.
Yeah, I think my SPDT hook up must have had one wire with the insulation under the screw, only had reverse at first. Then
I switched them, and it worked.
Well that should not have mattered, just reversed what direction the switch drove the spindle.
I switched them back and It was OK,must have been the connection.
