- Mar 12, 2021
- 63
Hello,
I know this is probably one of the more frequent topics "what machine to get" but I tend to get myself into research holes as I like to call it and end up looking like a conspiracy theorist with a stack of spreadsheets and red yarn going everywhere. So If anyone cares to read through and or give any suggestions of feedback on important features or considerations it would be much appreciated.
The shop is a basement shop with access from the garage but with wooden stairs, but the fools that built the house only used a 32 in entry door on it. Shop is decent size but given the above and the thought of ever having to remove it makes me lean to go "bench top" style of mills (and or lathes for that matter). garage technically a option but in WI even the garage gets quite cold and adding heating and wiring out there would also increase the budget sooo.
I had considered used machines but they seem far and few between in central WI and are usually much larger machines. That and unfamiliarity on what is "good or not" and or how to tell wear etc, I was less inclined to start out with a machine that requires me to rebuild it.
I'm a individual hobbyist not a business or anyone looking to do production runs, or be using the machine non stop. Predominately will likely be working in aluminum, pot metals, some plastic (delrin), with some steel work mixed in (no huge plans with steel but making the occasional replacement part and or want to maintain that capability). I'm not purchasing for automotive, cycling, or gunsmithing just enough times in my other hobbies I find myself really wanting to fix a part or make a tool that well requires a machinist or a mill to make or would be better if milled vs Dremel and right angle Grindered into shape. IE some tools on the list of things i would like to make and or improve is a decent belt grinder, die filer, various jigs and other tools for other work i do. Its a bit hard to bin the specific use cases as I only know some of them, and i know others certainly will come up as one uses and recognizes the uses of the tool.
I should add while I think CNC is neat I don't have the right temperament for it so at least conversion to CNC is not a major consideration in this decision (also famous last words).
That in mind I pretty much settled on PM, seeing their well regarded Customer service, or at least the fact that it has customer service and had ability to get parts if needed really seemed the place to go with, and their prices were close enough or even better to other resellers that it just made that part of the decision easy.
Budget $3000 on the upper limit on the machine itself (yeah i know tooling is a expensive slippery slope hence the budget).
Power: I can run a 220v outlet wherever I need to in the shop but no 3phase etc as I'm residential.
Based on my initial research reading and findings I thought the PM 932M (not the basic) fit the bill quite well its on the heavier side of bench type mills (heavy = more rigidity = good) still wrangle-able into the basement. At its price point ~2700 has nice features Powered Z axis and x axis power feed, and a good sized table with a decent work envelope that should be bigger than anything I need (famous last words).
However the PM 932M is out of stock and supply chains not being stellar with a sort of unknown restock time (seeing the other 932 family take several months to get in) I'm a bit less inclined to wait till I would guess near fall for them to restock the 932M. That leave me a few options I could step up to the PM 932M-PDF ($3k right at my limit) though I really don't think I would need or use the PDF feature, or I could side step to the less advertised PM-932V which is no power feeds but belt drive and VFD at $2600 (i would probably add on a x axis power feed if I went that route).
Here is where I have some questions
Geared vs Belt? I know belt will be a bit quieter, and in theory isn't belt more stupid proof as in if you do something really dumb the belt will slip vs mess up the gears or in this size of machine is it just hard to mess up the gears. Also would assume belt is lower maintenance.
VFD i roughly understand the science but question is, is it better low RPM torque than say brushless or than say geared. Is there concerns about the Chinese made electrics longevity vs the longevity of well Chinese made gears.
X power feed: desirable as it saves your arms, but also because you can get a constant x feed rate, better cuts and in theory better life on endmills if you feed them proper correct?
Z axis power "lift": i know not to call it feed as its not really designed to feed the Z that would be the job of the PDF, but really how useful is this or how often do you need to move the head up and down if working on say similar sized stuff. I guess it would depend if you do drilling operations etc that use a chuck as that would add a lot of height. Basically is it something I would regret not having
I had also considered like the PM 30MV as i liked brushless motors on other tools but really that and the other smaller mills really compared to the $2700 932M just didn't seem to come close in I guess "value". and really just the quill travel was a huge seller for me when looking at the 932 family or size bracket (which is based of the Rong Fu Rf45 at some point in its history if research tells me anything) .
Oh last notes in this book of a post. DRO is planned but I think I have the skills to mount one myself. Stand being 6'2" plan was to make my own as to my calcs all the sold ones would put everything short. Probably build around a tool chest cabinet get some useful space, as well as some sort of leveling, and or caster option to let me move it should I ever need to without needing a crane in the basement.
any comments, opinions, suggestions, or feedback are appreciated.
