- Sep 29, 2017
- 2,254
T
Thanks for the info. I browsed around and found it on another machinist site,I think it was "practical machist". It was discussed there on wich gear to use for a metric leadscrew.To get a more accurate reading with your caliper, open the caliper out and measure as many threads as possible. Then divide that length by the number of threads in your measurement. Be aware that the result does not have to be a round number, it could be 12.5mm for example.
I am no gear expert but to get the circumference of a 15T gear to match your lead screw just measure the length of 15 threads on the screw, then divide that number by pi (3.1416). For the 14T gear measure 14 threads on the screw. That will give you a ballpark diameter for the gear.
How did you determine that a 14 and 15 tooth gear is required?
