- Aug 3, 2017
- 2,437
You could always just make a gearbox for the end of the motorA jack shaft would be good but I've no idea where to get one and space is quite tight in there
Make a gear box??
You say that like you're not even insane
2 | 5913K62 | Low-Profile Mounted Sealed Steel Ball Bearing for 5/8" Shaft Diameter | $10.95 | $21.90 |
1 | 5227T272 | Tight-Tolerance 12L14 Carbon Steel Rod Ultra-Machinable, 5/8" Diameter, 1 ft. Length | $7.86 | $7.86 |
1 | 98510A117 | Undersized Steel Machine Key Stock Zinc-Plated, 3/16" x 3/16", 12" Long | $1.05 | $1.05 |
1 | 6245K16 | Pulley for 4L, A V-Belts, 2" OD, for 5/8" Shaft Diameter | $6.25 | $6.25 |
1 | 6245K53 | Pulley for 4L, A V-Belts, 7" OD, for 5/8" Shaft Diameter | $24.89 | $24.89 |
| | | Merchandise Total | $61.95 |
On the treadmill motors I've encountered, the pulley is LEFT-HAND threaded onto the motor shaft. Of course, yours may be different ... but it might be worth a try.Bigger pulleys!
I actually thought of that on day one but couldn't get the big fly wheel pulley off the motor spindle so put it out of my mind.
