@Investigator have you tried callin or emailing Scott Logan with this question?I would reach out to Scott Logan and ask him. Must have been a way, the bolt at the rear doesn’t lock it?
John
Next you advance center by turning nut to advance bar with center in it.
I am showing a bolt to advance bar. But you can make a hand wheel with a threaded center in place of a bolt.
No drilling at all on the turret. Slip the stop bar out and you are back to standard operating turret.
Or posting the question in the Logan’s group?
Log In
groups.io
As long as as you make your spacer fit across the ways and use as a regid stop I see no reason stop could not be 1 inch thick and 4 or more inches wide.Jim: I like the idea. I'm thinking I want the ram at full extension to give more room for the saddle to move back and forth. Have you had any issues with being able to work in that envelope?
Wachuko: I posted on the Logan Facebook group, I've 'talked' with Scott Logan on that in the past. However I haven't gotten any answers there either.
