- Apr 8, 2013
Like others have said, the term Gunsmith lathe" is a jello-like term that can't be decisively nailed down. I have the Grizzly G4003G "gunsmith" lathe. When compared to the non gunsmith version (G4003) it has a slightly narrower headstock (about 3/4"), an outboard spider and upgraded headstock bearings. It also has a QC gearbox and will pass a 1.5" barrel blank thru the bore. I've already built a rifle on it and I'm just delighted with the machine. That said, virtually any decent lathe will do gunsmithing with some basic minimum capacities. It needs to be able to pass a 1.5 inch barrel blank thru the bore. It needs a QC gearbox. These two are absolute deal breakers for me when gunsmithing. An factory outboard spider is nice but you can add one if needed, It will add to the headstock depth increasing the minimum barrel length that you can work on without added fixturing. A handy option to consider (which I don't have) is a taper attachment. It's tedious contouring a rifle barrel without one. When turning a taper via an offset tailstock, the follower rest doesn't work and I get chatter when turning the full length on centers. I get around this by calculating the taper and turning the barrel a foot at a time. The final polishing takes out the lines between sections. Not the end of the world but it takes a lot more time.
