I am not sure where to post this. So moderators feel free to relocate.
I am needing/ wanting to build a vacuum box for infusing wood panels, etc. using "cactus juice" and other acrylic stabilizers/and or epoxies. So I can not use acrylic chambers. This brings me to using aluminum or stainless for the box. I was thinking along the lines of a box 24" long x 18" wide x 8" to 12" deep. To infuse multiple panels at once.
Most of the smaller vacuum systems I have seen were designed for pen makers and other smaller pieces of wood. The vacuum pumps are generally around 5 to 9 CFM and some are listed as creating a vacuum of 5 or 6 Pascals. So not much it seems. I am looking for a pump to go with 25"Hg at the moment. My question is what thickness should I use to avoid any collapse breaking the seal of the box. I was thinking 0.25" of either 5052 or 6061 for the sides and .375" for the bottom and top.
Is this over kill? The top will have the gauges, inlets and outlets tapped into it, but I wouldn't think would affect strength. Thanks in advance.
