- Dec 18, 2013
- 2,012
You risk DEATH fooling around with building pressure vessels if you don't know what you are doing. Have you looked at Binks or Devilbiss pressure pots, they are available up to 10 gallons in size there's quite a bit of internal volume and you can find them used, sometimes in mint condition. I was just looking at these on ebay the other day. These are constructed of steel or stainless, take a look at their lids and hold down clamps.
For vacuum pumps check this place http://www.nationaltoolwarehouse.com/6-CFM-2-Stage-Vacuum-Pump-R-12R-134a-P28784C295.aspx they cater to the HVAC guys and blow pumps out the door at typically the lowest prices. I had a pair of these 6cfm babies when I was thermoforming ABS sheets on a vacuum table. I also had a 10 gallon tank, I would draw down the tank to zero, fire up both pumps blasting then open the vacuum table valve and WHAM slam it with the tank reserve vacuum and both pumps to draw down the ABS sheet in less than 1 second. You have to work fast when vacuum forming thermoplastic sheet.
If a pressure pot is large enough you have the additional option of using pressure. You can suck all the air out of a resin using vacuum but you need lots of extra volume in your container because the resin will expand greatly as you suck the air out, it foams up and expands before falling back down. In pressure forming/casting you basically crush the air bubbles to microscopic size, the resin never expands.
Pressure/vacuum you can have a bunch of fun with this stuff but stay safe, that's my 2 cents worth.
