- Sep 6, 2011
- 49
Harry, if it just a few welds here and there, go the a shop! You will pay just for the welding.
Just prepare the job , procuring the metal, cutting, grinding etc..
Then bring the whole mess to a shop with a good sketch and bring it back to the shop where you can grind everything smooth and paint to your lacking etc.. Job (well) done! Preparation and finishing is what is costly, just the welding is not much. Plus a good welder will make you very good weld, easy to clean with a grinder, and this guy will get things done much faster than we will ever be able to do!
You will also save on the electricals for your little shop where a 30 or 40 amps circuit will then probably be sufficient! A small mill, a small lathe (say 2HP or less), some lights and a few outlets then you're good to go. For this, if the code allows it, you can simply run a 'direct burial' type of cable that you can bury directly in the earth. When it gets cold, use a small kerosene space heater, like you would find in a camping or RV equipment store.
In NC you have nothing Like I have here (Quebec) where it gets to -10°F for weeks and so far 6 feet of snow accumulated!
