[4]
Where can I source a taper lock pulley like this?
[3]
[10] Like what you see?
slow-poke
Active Member
Dec 9, 2016
69
The pulley on my old mill is not in the greatest condition and I would like to replace it with a taper lock pulley for better fit. The original is pretty beat up and has a tendency to loosen up over time.
The pulley actually has 3 grooves, however I never use the smallest one (not shown on top)
This is used with a B34 V-Belt and a 2HP, 3-phase motor max RPM = 2200
The motor shaft is 0.875"
The diameters shown are what I have now, the replacement does not have to be exact, anything +/- 10% or so would be fine, as I control this with a VFD
If the 1.58" hub depth is a problem, I can shift the motor up closer to the pulley (somewhat) if need be.
Can anyone point me to a source for a suitable replacement?
Thanks,
roadie33
Dec 11, 2014
845
I've ordered some from Surplus Center like that. Just need to know the bore and pulley sizes. They can help you match it up.
Kernbigo
Apr 8, 2012
730
if the pulley groves are good use a fenner drive they work great
NortonDommi
Active Member
Nov 15, 2016
431
Any industrial transmission supplier or bearing factor will have different size pulleys and hubs in both Imperial and Metric. If necessary you can stack individual pulleys to make a cluster.
F
f350ca
Guest - Please Register!
You could buy the taperlock sleeve then bore your pulley to match it.
Greg
Kernbigo
Apr 8, 2012
730
Google Fenner it will explain, they work great, if your shafts or keyway is worn
Sent from my SM-G900V using Tapatalk
P. Waller
H-M Platinum Supporter ($50)
Mar 10, 2018
913
If there is room for it a key less bushing would work but I doubt that the hub has the extra diameter for it.
Search for key less locking drive bushings, this will result in more choices then Fenner.
You must have a substantial wall thickness as they develope a great deal of radial force.
McM has them https://www.mcmaster.com/#keyless-bushings/=1dl419y
TORQUIN
Active Member
Mar 19, 2015
120
When I bought my Monarch 12CK and found the motor drive pulley, with hub and key and set screws, wobbling around I switched to the pulley with a tapered hub, source from Zoro.com. It works great, and I can position the pulley wherever I want to the shaft then tighten the hub. It works great.
Chris
markba633csi
H-M Supporter - Gold Member
Apr 30, 2015
3,174
Browning used to make good taper-locs
bfd
Staff member
Sep 9, 2016
425
your local bearing supplier should help you size the correct taper lock bushing. bill
Larry42
Active Member
Jun 22, 2016
76
I use Motion Industries for such things. They have outlets all over the country and fast service.
slow-poke
Active Member
Dec 9, 2016
69
I was wandering around Princess Auto and they had just what I needed.
Thanks
[6]
[5] [7]
