2014 POTD Thread Archive
Repaired a Jeep suspension link over the weekend. The snap-ring had popped out and damaged the groove so I machined a new one and then cut the damaged one off the link and welded the newly machined one on. I then beadblasted and painted it as close as I could come with some paint I had on the shelf.
Here is the one with the damaged end link. I quickly welded the snap ring in place a few weeks ago until I could find time to build a replacement end link.
Old one cut off.
Machining a new end link. Had to use my custom made snap-ring grooving tool that I just ground from HSS.
Machining complete.
Test fit of the bushings and sphrerical ball prior to welding.
Proper fit-up is crucial to a strong weld and overall strength of the part. Especially being a suspension component.
Weld completed.
After bead blasting, priming and painting.
Also had a spare piston kicking around the shop that I no longer had a need for so I decided to machine a base for it and mill a pocket in it for a business card holder to put on my desk at work.
Pocket milled.
I machined the base .001" smaller for a pressed fit to the bottom of the piston skirt.
Completed.
Rearranged the shop a little. Moved my main workbench and press to the middle of the shop and ran power to the bench so I don't have to drag an extension cord out all the time.
You can bet your bippy that's gonna be copied! I'm gonna "Monkey see - Monkey" do that! Neato, Keeno.
Decided as I have had the lathe for almost a year now was time to do the freshman project and build a simple model steam engine.
Looked over various plans and decided to build something based on a Elmer's "Fancy" (vertical single cylinder wobbler), but more the size of the horizontal "Fancy II".
Have got the cylinder, piston, column and flywheel done so far.
I been working on an indexer, since I have needed one at least three times in the last 3 months, it is time to build one. these pictures are of the progress so far. it will be done soon. I could have bought one for a few hundred dollars, but this one has cost nothing but my time.
Mark, would you care to post this up in members projects or something with a build log and more details?
It sure looks great
Cheers Phil
I made myself a kinda borescope - meant for illuminating and looking into deep holes. It's pretty simple, and very inexpensive. Just a 1" white PVC ell, a small chunk of window glass, a cheap flashlight, and a PVC reducing bushing bored out to fit the flashlight.
The first photo shows the parts. The PVC ell is milled at a 45 degree angle, going through the point of intersection of the centerlines of the two legs. The glass is crudely hacked out (didn't have a glass cutter on hand) and glued to the 45 degree face with Loctite "GO2 Glue." I used a 1" x 1/2" reducing bushing for the [FREE] black Harbor Freight LED flashlight. I also made an adapter for another, brighter flashlight out of a 1" x 3/4" reducing bushing.
The second photo shows the relative amount of light that reflects "downhole" off the inside face of the glass vs what is lost out the side. True, most of the light is lost, but the reflected light is still strong enough to give good illumination downhole. I suppose I could have found a real-live 50% beam splitter, but that would have taken real money!
The third photo shows how well the device illuminates the inside of the other flashlight's barrel. It's about 4 1/2" deep.
Very slick. I'll certainly be making one of those in the near future as it would come in very handy on a regular basis.
Thanks much,
-Ron
Very cool. I'll be making one of those. I could have used that tonight while working on a project.
