- Aug 29, 2016
- 838
Page 65 (aka 67 of 92) in the catalog.
And if you look at the headstock specs on page 39, of the same catalog, it says that the spindle is a MT2 but it is not. MT2 has a large diameter of .7000. The bore of my spindle, inside the 1 1/2-8" end, is about .905. An MT3 taper is supposed to be .9380 at the large end.Page 65 (aka 67 of 92) in the catalog.
Yes, the spindle bore is 3mt.
On these lathes, the main reason you use a 2mt dead center with a sleeve is for using a lathe dog. The 3mt dead center usually sticks out too far so you have trouble grabbing the work.
Hi Jack,
My ~1937 Southbend 9" (catalog number 409R) does have a MT3 in the headstock.
I have used collets, and adapters in it with no issues.
I was hoping you had a male MT3 to check yours with.
I have not heard of a Southbend proprietary "close to MT3, but not quite" taper before.
-brino
