- Jun 7, 2019
- 151
Thanks Ray!
Sent from my LM-V405 using Tapatalk
Thanks Ray!
Thanks again Ray! Lol //cloud.tapatalk.com/s/5dc8599ad518e/1110191038.mp4
Glad you got it fixed!!Zamboni2354, your post let me solve that quill lock problem. I see that the way it works is that when you rotate the quill lock lever clockwise to vertical, it pulls in the outboard half clamp and pinches the quill. But in my lathe, there was no way to get the shaft that runs through the half clamps to rotate! No setscrew, key, etc. The only way I could see this working was if the lock handle screwed down on the shaft, but for some reason, the lock handle was too short to reach the threaded shaft. So I filled the gap with a brass slug, and adjusted the nominal separation of the half clamps to be shorter. A slight bit of trial and error got a setting that has NO friction unlocked, and a solid lock when engaged. It only takes a quarter turn of the shaft, and I kept the pin that stops the lock handle vertically.
So, I love ya, man.
I sometimes use Permatex 85224 for gaskets - oil / heat / gas does not phase it...
WRT oil passages - there is a locating pin on one side and the hole I marked which is where the oil goes. It will lubricate the front and rear ways. I verified this by putting an air line up against the 'in' and could feel air in the 'out'
Ray
