I am currently out of the country and get back on Thursday. Bottom line is I am not sure. Can you take a couple of pictures of what you are talking about?
I ended up pulling the plugs and clearing the lines in the casting. I ended up drilling and tapping the plug to pull them out. So now ill make new plugs.
@rbahr thanks for replying so quickly, enjoy your vacation.
Got the apron opened up. It looked pretty good inside. You could see some wear on some of the gears, but nothing was broken. I simply cleaned it up as best I could. There wasn't a filter on the oil inlet pipe for the one shot. I had ordered this from McMaster-Carr before finding out from Ray what original filter was like. I tested it and it works good. I also opened the headstock and it looks good. Just going to give it a oil change.
