- Nov 15, 2016
- 943
From quite a bit of research on this some years ago it turns out a LOT of manufacturers lift lathes by a sling under the chuck and another around the tailstock end of the bed, even on very large lathes. If holes for bars in the bed or stand are provided then may as well use them or a lifting plate that lifts from under the ways. With regard to stresses think about this. A 1/4" UNC bolt grade 5 has a tensile strength of 1.35 Ton, a 3/8" bolt 3.3 Ton - one bolt. Think about the forces acting upon a turbo-charged Diesel engine under full load. A plate,(essentially what a headstock is),bolted down can withstand more force than the individual bolts restraining it can. Then think about the hammering an axle bearing on the average car or pickup truck takes, not only rotational but shock loading as well.
That mover probably did know exactly what he was doing, especially if he moves a lot of machinery.
I'd stop worrying and start turning.
