- Nov 30, 2022
- 105
Update, Ted...You haven't said what your budget is, so that of course has a huge impact on your options. And, as has been mentioned, your geographic location has a lot to do with used machinery availability and prices. Concerning moving heavy machinery, as has been mentioned here, it is very doable, but I would caution that lathes are very top heavy and are easily tipped over if you're not careful. I would advise having knowledgeable help available if you decide to move a heavy lathe.
Concerning spindle speeds, I can tell you that for me personally, I have a 14x40, geared head lathe with 40 to 1500 RPM spindle speed range, and I very seldom use the 1500 RPM range. On the other hand, I have used the 40 RPM range hundreds of times. Another important aspect is spindle bore diameter. Mine has a 2" spindle bore and is generally adequate, but there certainly have been times I wish it was larger. Bigger is better.
My lathe runs on 240V, three phase and I use a rotary phase converter. I have never had any desire to have it powered by a VFD. Another important factor is threading capability. Both metric and imperial capability without having to use change-gears is important to me, may not be for you.
You really need to evaluate what your needs are both present and future and make a list of the features on a lathe will be necessary to accomplish those needs.
As they say, just my two cents.
Ted
Well, it looks like you've stated your budget while I was typing.
The wife is onboard and the $2K of aggravation bumps my budget up. My thought for new: https://www.toolots.com/ng-frontend...d+Metal+Lathe+BT1440GQTD-3+with+2"+Bore+&+DRO
