- Mar 12, 2014
- 1,531
Mike isn't the minimum 90 rpm speed a bit high for threading on the manual machine? I see the lowest speed with the variable option is 50 rpms. Also will a keyless chuck fit all the way into the tailstock with the quill fully retracted e.g. so you still have the full 4 inches of travel?
Charles, depending on what you are threading but for the most part 90RPM is a bit high for manual threading. I have done it on occassion and it works but again, depending on what material and orientation of the threads being cut.
I purchased a Jacobs keyless chuck and I had to cut and grind just a bit off of the backside of the arbor so I still have full travel of the tailstock. My Albrect 3/8" that I had didn't require any modification at all to have full stroke at the tailstock.
Mike.
