F
Firestopper
Forum Guest
Register Today
What do you all mount your arbor presses on? Bolt it on the workbench and cut a hole beneath for long work? Would a small stand like this work?View attachment 259257
Some time back, this stand was built for another member for his Enco press.
sanddan was kind enough to draw it up for others to follow the same. If you choose to use his drawings and don't want to use casters, remember to make the legs longer to suit your stature.
The outrigger is stowed pointing up and at the rear to keep the footprint small when not in use.
Outrigger in place adding stability for pressing.
sanddan took the time to draw up the project for others to use. Thanks Dan!
I never really got feedback on the performance but hopefully it works well.
Paco
