- Mar 22, 2022
- 345
Gear box positioned on the press.
Gears are a slip fit but over time burrs build up and slip requires a little help.
Some time later
Bearings
Found 9/16" ID x 1 3/8" x 7/16" bearings for the cone gear shaft from bearings direct.
1622 zzc3, .0025 or so under sized on the OD which is not a problem.
Bushings
Made new tumbler shaft bushings and dog gear bushing.
Clausing had the tumbler shaft in stock so went that route as opposed to reworking the chewed up end of original.
Almost back together
Some time later
Bearings
Bushings
