A few misnomers (marketing gimmicks) as too inflated numbers on compressors and motor driven tools. The motor is rated in SPL which is peak Hp, not continuous Hp. The peak horsepower number is taken from the fraction of a second when the motor first kicks on and the start windings engage. That number can be many times higher than the continuous HP. A true single phase 5Hp motor will draw around 26-28A. The compressor is rated in SCFM, which is based on ideal conditions, calculated, actual performance is measured in CFM at a given pressure which is lower. The pump rating you have from what I gather is also based on a true 3 Hp motor, not peak Hp, the rated air output is at a pump speed of 1000 RPM. CFM is affected by pump speed and pressure, the RPM will decrease as the pressure increases, and CFM will continue to decline. A number of factors that effect the air fill times, so more like a 2.5 Hp motor driving an 8 CFM @90 PSI air pump.
Motor: MC019000AV MC019000SJ
5 HP, SPL
230/240 VOLT
3450 RPM
56 FRAME
14.5 AMPS
5/8″ SHAFT SIZE
