Wow, that's great. Now with the other tank?
Did I see your set up in another post with the tanks mounted high?
I like the space savings.
Sounds like you've got it sorted out. The calculators show something like 2:30 so I'd be happy with 3:00...that says the pump is working as it should, and probably just as good as new. The good thing is you have a baseline now so if you see a big change in the future you'll know it's time to start digging into it.Separated the two tanks this afternoon. Checked belt tension.
Turns out the belt was loose, likely because it was brand new so has worn in.
Cut the 0-60 psi time in more than half; 3 mins vs 1:22.
Time to 125 psi is now 3:22 on a single tank. Not under any illusions that adding the second tank will mean 6:44 to 125psi but it suspect it won’t be far off.
