So what I'm hearing is the the stock index cutters that come with the HF mini lathe are not the right call.Any good right hand tool/holder that has a sharp cutting edge and has positive geometry would work. HSS would have the lowest pressure and therefore limit deflection of the shaft.
I personally would use a tangential tool holder but that is because I have one. A CCMT 21.52 RH tool holder (SCLCR) would work as well.
While I still don't know why they do it, a RH tool is meant to cut to the Left towards the chuck.
I personally don't care for triangle inserts most of the time.
I would use HSS for threading but you would need to learn to grind it. I also have a number 1 top notch tool that takes threading inserts that works well but probably more expensive than many want. Laydown threading tool holders seem to be much more reasonably priced but I have not really used the
Oh, so hhs cuts better ( e.g., less pressure) than carbide?They aren't great, but they aren't crap. What you run into is that the inserts tend to be molded and not very sharp. That increases tool pressure and deflection of the part. On a mini lathe those can be very important.
You can get honed/polished inserts. They are generally intended for aluminum, but will cut steels nicely. They won't last as long, but will work better, particularly for a small machine.
Grinding HSS is probably the best option for a mini. Get it really sharp and you can get very good cutting with it.
Have a look in the Beginners section for @mikey's excellent treatise on grinding HSS tools.Oh, so hhs cuts better ( e.g., less pressure) than carbide?
How difficult is it to get good at sharpening hhs cutters?
One thing I learned is you don't have to be all that good at grinding cutters to be better than carbide on a lathe. I did pretty well just eyeballing angles and not really going for a particular angle (just watched the ToT video), and did better than the import carbide.Oh, so hhs cuts better ( e.g., less pressure) than carbide?
