- Jan 26, 2022
- 36
That's a good thought.@Alcap Were it me I'd cut the tang off, drill and tap the end for 1/4-20 or maybe 3/8-16 (if there's sufficient material) so that a drawbar of threaded rod could be used.
You don't want the 'cones' to be too high. But it depends on whether you're using ring blanks or if your cutting them entirely out of raw material. That said, ring mandrels of this kind I car about (mostly using ring blanks) usually come with multiple sets of 'cones' for different size rings.Is it OK that the cones will hide the edges of the ring? Should you consider an expanding mandrel type setup?
Expanding mandrels are great too. I made a wooden one but it was wonky. The metal ones are often sold in sets in order to cover all the ring sizes and so they can get quite expensive. Like this:
IMHO, this is the most-brilliant design of all of them. $125.
