- Jan 26, 2022
- 36
Ah, good to learn. Makes perfect sense. Two questions...Probably not the drill but the tap. You will always get wobble like this. Drill and ream a hole (next stock size up) in your soft shank. Use green locktite to retain the new piece of stock(say 3/8 if your doing 5/16 threads). After it sets up for 24 hours cut the glued in shank down to 5/16. Cut threads single point but not under where the ring sets. Just like the unimandrel above. Even better, don't cut any threads under any part of the mandrel at max extension(smallest size ring you will do) and use spacers under the nut for bigger rings
What did you mean by "single point"?
Any tips on cutting threads? I've never done that. I've watched some youtube videos.
