The earlier pics that showed 1/4” of collet protruding from the spindle nose even when drawn up with the drawbar say that something other than a rough spindle taper is at fault here.
Are the diameters of the collet end of the R8 collet and the interior of the spindle nose similar?
If they aren’t, there’s no way the R8 collet is going to draw up completely.
Have you tried blueing the inside of the taper and seeing where the R8 collet makes contact?
There are shops specializing in repair grinding of spindles...........even with spindle still in machine. I'm sure taking it in will be less cost than service in place.
Are you able to tilt the head and rotate the turret on your machine? If it does you can grind the spindle yourself.
Here's a video that shows the setup.
This shop maybe be able to regrind if you decide to go that route.
I just noticed what appears to be an M4 setscrew which is about 3 1/2 inches from the nose of the spindle. It looksmildly staked over is that a feasible location for a locating pin for an R8 Collett?
