You make cutters?? For the Mill? Wha...how...i....what metal do you use? How do you harden it? I'm impressed!! I didnt know that was even possible!I only buy what I need to do the job I'm doing now ! Otherwise I make the cutters/tools that I need.
I'll have to see if i can find your thread, and WTH are you up at 2:20 in the morning??!?Yes ! why not.
The cutters that you need will depend upon the job you want to do.
No hardening involved. You simply grab broken taps, lathe tools, almost anything using HSS and adapt it to suit.
My most used mill tool is a fly cutter. I done slots, dovetails, rebates etc with one. I did post pictures of a dovetail slide that I made, done entirely with a fly cutter. OK I did use a drill and a tap, but that was all.
I’ve had a lot of good luck with the “Kodiak Cutting Tools” brand off of Amazon
