Hello,
Starting a small basement machine shop. Max budget $10K and need three machines: CNC mill, lathe and surface grinder.
I plan to spend less on the lathe and get a mini lathe while spend more on a surface grinder and milling machine which will be converted to CNC.
Between the surface grinder and milling machine, I plan to not go over $3K for a milling machine and spend the bulk of the budget on the surface grinder.
At of all the machines the surface grinder is one of my most favorites, it's able to make parts which holds tolerances sub micron and I can do some really nice projects/work with it.
Would like to hear what everyone have to say and experience with the Grizzly G5963 surface grinder.
I see its being sold for $4,361.16 after tax and shipping from the Grizzly website.
To be frank, which seems to be the cheapest deal in the market right now, specially coming from Grizzly.
I really do not want to buy a used surface grinder because it's the only machine which has the most risks of not being able to produce perfect tolerances.
I have also seen many YouTubers not being able to repair or rebuild their surface grinder back into factory specifications.
So with a surface grinder, it's best to buy it brand new for the safety of good investment.
Anyone had any issues with the Grizzly G5963 surface grinder? Something I might need to know about?
I would like to make some precision ground parallels, plates and spindles (using a special attachment).
I've seen some skilled precision machinists on YouTube precision ground some scratch made parallels on their used surface grinder which was able to hold less than 1 tenth tolerance, really remarkable.
Has anyone ever attempted/accomplished to obtain tolerances less than 1 tenth on their imported surface grinder similar priced to the Grizzly G5963?
Think it's "doable" to hold slightly less than 1 tenth on a brand new Grizzly G5963 surface grinder when putting some good care and attention?
If it's possible and proven to be so, I guess I'll buy it.
Thanks for any advice and information.
