- Apr 29, 2019
- 2,066
1) The two .089 holes are for locators for pins to be installed at assembly. It will take some messing around to get the trunion exactly lined up and at that time the owner of that Dividing Head can drill and pin it to make alignment perfect if it is ever taken apart for cleaning. These will allow for either an .093 or .125 pin. I made the screw holes with some extra clearance to allow for adjustment. There are just 2 many dimensions between to realistically have them just line up.Woohoo! This is gettin' real, y'all!
I've got a few questions.
1) The Auxiliary Base has two .089 holes. I assumed they would be for locating pins, but didn't see corresponding holes in the Main Base. What's up with that?
2) The slots for the locating blocks on the bottom of the Main Base. Any reason they can't run the length of the base?
3) The hole for the Trunnion on the Main and Auxiliary Bases would need to be at the exact same height. The numbers on the drawing aren't adding up. I assumed I would clamp the bases together for final boring of the trunnion hole, using the bottom to level set them.
2) No reason they can not run the length and width of the base
3) I made the Aux base short on the bottom to be sure that it will not protrude below the bottom of the base and cause a tilt when set on the table. If you are making both parts and can line bor both holes then you could screw and pin the 2 parts together before boring. I was not sure if you could bore 6 inches deep.
There will be some parts that are designed and toleranced expecting that 2 different people will be making them, IF the same person is making both parts the tolerances can be opened up a lot and that one perrson can just make them to fit together. This is part of what I will be talking to each of you on once I get the first pass of the drawings done.
