- Feb 7, 2013
- 792
Well I did not really need it I would not go out and buy one but I always wanted to build a small version of a spool gun similar to the one I had to use when I worked in a machine shop something that I could hook up to a 120V wirefeed or a pair of car batteries. I am sorry I did not do a picture by picture on how I made it I just thought I would post this I just got done with it and some testing everything appears correct good isolation of parts, steady motor speed and drives the wire through the liner perfectly, the liner is teflon.
The motor is an army surplus motor it started its life from the directional stabs on an ICM missile I have a few of these motors and love there small size and power. I made every part on this with the exception of the motor and a few screws I did make the off set gearbox for the motor however so the handle would be centered I made the gear box out of aluminum and the gears are about a 1/2 in dia. It balances out real well and is small for tight spaces. You can imagine the small size of the gun because the wire spool is 4" in dia.
