Over the weekend I finished welding up the center web support and welded the base for the Leveling casters, everything went better than I expected.
I am pretty much a hobby welder, so I had a couple welding hurdles to overcome and learn to problem solve issues such as filling gaps & different metal thickness being welded together. I got the bases welded up and everything was going well except for a mistake I made while getting the bases ready to mount up.
After welding up the bases, my train of thought got de-railed from work calls and what not, and instead of drilling the socket access holes on the exposed side I started drilling the holes on the flush side of a base that mates with the pedestal, I was drilling the 2nd hole before I realized what I had done... needless to say I went into panic mode trying to figure out how I was going to continue.
I didn't want to recreate a new base, so I watched a few videos looking for ideas how to close the holes up and found one that uses a copper plate to close the holes with... I looked around but could not find any copper plates on a Sunday. then it hit me I have washers the same thickness as the metal with a 3/8" hole that is the same size as the hardware I'm using... I welded them in leaving the same size hole I need.
Boy did I luck out and divert what I thought was a disaster, 30 minutes later I was back in business and moving along.
With all my self-made drama out of the way the rest of the day went great.
The Leveling caster uses a 1/2" stud, washer and bolt to mount it.
The casters hold the stand about 3/16" off the ground which is all I should need to gain access the back of the lathe when needed.
During the week I'll try and add a floor to the left pedestal, Thanks for looking.
