Jake, this was a great and lengthy reply. Thanks so much!Probably an intentional undersize thread. That'll allow a M6X1m thread. That'll fully screw into a straight threaded hole, or a tapered hole. Both are out there. Don't get too hung up on "exact" thread forms on things like this. There are usually some liberties taken to make the whole thing fit into a larger subsystem within the various systems of threads.
Provincial, thanks so much for your extended reply! I appreciate it.Don't concern yourself about the reasoning behind the specification for 1/8" pipe thread. Just get fittings that have 1/8" male pipe threads so that they will match the holes Bridgeport tapped. If you want to hide the tubing, some new holes will need to be drilled and tapped. The old holes on the front of the saddle can be plugged with hollow head pipe plugs if you go that route.
I don't care for push loc fittings as they seem to leak down the road.
NO, I thought you were trying to level your lathe this weekend... again lolIf they didn't leak air , I would be out of a job . Oh wait , I am anyway now .
You know me all too well , and I'll start at 6 pm with the lathe leveling .NO, I thought you were trying to level your lathe this weekend... again lol
I need to stop by the store for more leveling fluid, some how I ran out !?!
