- Jul 28, 2017
- 2,402
I bought some 1uf plastic SMT's for a future from-the-ground-up detector board. The plastic caps are substantially larger than 1206's.
X7R and X5R ceramics are highly microphonic, particularly if they have a voltage across them. They are real similar in composition to real-deal piezoelectric devices. They also have higher leakage than polymer caps. There are reasons that it's a bad idea to put high-K ceramic capacitors in the signal path of audio amplifiers.
On a different subject, I have a couple of XRF spectrum I want to share. The first is for 1018 HRS, and the second is for aluminum. I'm _finally_ seeing a peak I believe may actually represent iron! But there also is a pretty strong peak from something else. That peak looks pretty much like the aluminum-only sample.
I think that high aluminum background is secondary xray fluorescence coming from my aluminum "focusing ring", perhaps generated by 6Kev xrays from the steel sample itself (!). I may have shot myself in the foot there, so you folks going with a plastic 3D printed focusing ring will likely get much better results right out of the chute.
Iron + "X" (the iron is the peak on the far right):
Aluminum + a little bit of "Y":
As you can see, the "X" looks a lot like aluminum and the "Y" looks like it could be iron, possibly coming from my little source disks -- or perhaps fastener hardware in my enclosure. I will try strategically placing some lead shielding here and there to see if I can get rid of the extraneous iron peak.
Right now I'm reluctant to scavenge my sources, preferring to keep the current setup for comparison purposes. So I just ordered 8 more sources from Ali Express, too. They are selling them for a lot less than Ebay right now. The sources should arrive the first week of March. This isn't too bad because I want to spend some time on the driver code for my 1MSPS ADC. It will be interesting to see how many "noise bits" my board design has.
