Quick update. I attempted to order a Grizzly saddle today, and Grizzly canceled the order, they won't have any until December 8th at the earliest. Back to square one.
I did find a blog with a cnc conversion that has screw mounts exactly like the ones in my PM25MV. I may have to do what he did, I would hate that, because i already bought the cnc kit from Automation Technology, and I will only get to use about half of it, and I will have to buy a drill press to do that. (I'm really short on space in the shop, which is why i don't have a drill press already).
The blog is a Titan TM20V machine, but it's set up exactly the same as the current PM25MV.
http://www.homanndesigns.com/index....ersion-part-2&catid=34:cnc-projects&Itemid=55
So, my options at this point are:
1. Build new ball nut mounts myself, and not use the kit that i already have.
2. Slot the current saddle so it can use the G0704 nut mounts, then drill and tap for the screws to tighten them down, then make an adapter plate for the Z axis.
3. Buy the new saddle from Grizzly anyway, hope it fits, and wait until they get them in, in December.
4. Another option that is a little spendy, but would work the best with the kit components i already have: Buy a base, saddle, table, and column from Grizzly, and mount my head on it. The whole setup costs around $600.
I think i am going to try option 2. I know some machine shop guys through my work, and they might slot and tap the saddle for me, without breaking my piggy bank.
On a more positive note, I put power to the control box last night, and almost everything worked the way it is supposed to. The only thing that did not work was the rear cooling fan. It did not come on at all, and the 48v to 24v converter that i bought to run it got super hot. Not sure what is going on there, but i'll have to check it out some more, it was very late when i powered it up, so i didn't spend much time troubleshooting. It's just a basic 120mm fan anyway, I will probably just replace it with a cheap 120vac fan then wire it up to the 120v circuit and be done with it. The 48v to 24v converter was very inexpensive, so i'm not out much. A new fan will cost more than it did, and these fans are cheap.
I got all the wires tidied up on one side of the box, and tonight i will hopefully get the other side done. Depends on how i feel, i caught a cold over the weekend, so may not feel like doing any work on it later.
