- Nov 23, 2014
- 2,607
I probably use a GTN-2 and 3 the most. Also use a T-shaped HSS 5/8" tall blade and MGMN200/300 inserts. I've had the same luck you did with the MGMN though it depends on the material (had good luck with aluminum and brass).
I go to back gear when parting steel with the GTN-2 or 3, had good luck with them. Also good results with stainless and drill rod.
I can't recall having a problem with the HSS with any material. I follow Tom's Technique's recommendation of sharpening the tool with each use.
Bruce
Bruce
