- Jun 12, 2014
- 4,810
I installed a control system and helped my friend setup his Acra 1640 which is the same model lathe. Easy move with a fork lift under the base, I also used a forklift to get mine into the garage. Might look through his thread below. I have mounted my last two lathes near the garage door facing in, when running power to the machine I use 4 wire and breakout 120VAC at the machine. It is an impressive lathe and QMT version has a larger spindle bore in their version. Chucks are very heavy, but TIR was almost not measurable. I had considered it but was just too big and heavy for my needs.
NEW ACRA 1640TE
The machine was ordered mid December of 2017 from ACRA Machinery. The machine took a few weeks to arrive from Taiwan and was shipped to the port of LA, then onto Ranch Cucamonga where ACRA is located. The machine was then delivered to my location via flatbed. The machine sustained a fair amount...
www.hobby-machinist.com
