- Feb 24, 2018
- 1,044
A 12 in. machine is right on the cusp. You could get by with an AXA, but might need a spacer under the TP to get to optimum height. A BXA is a larger and therefore more rigid TP. Of course, the machine itself may be the limiting factor when it comes to rigidity. Your call.
According to Dorian and Aloris, you will not gain any rigidity going from a AXA to a BXA, in a home shop situation, as on most lathes the carriage and the compound will flex long before the tool post will.
