The electrical motor is gonna give me fits... They had a 3/4 hp motor, but it did not fit quite right and it looked like the mounts were under tons of stress. Now I am trying to put it back but parts keep hitting in places I don't think it should hit. It came wired for 110 volts, and it can be wired for 220. It has a thread on chuck, which reminds me of safety issues if placed into reverse it "could" un-thread itself. I have a nice 6 terminal drum switch, (see the very first photo).
Now that being said, I have a brand new 1/2 hp motor that is smaller and fits on the mount much better, it also can be wired for 220, just needs a pulley which I can get locally. Not sure which way to go.......
On to the next thought, the belt cover acts as a tensioner for the belt. I am thinking that I want zero slippage, period. So anyone had an slippage issues with the current set up?
Also note the mounts under the cover that are supposed to be rubber??? I made some out of Delrin, before the light went on. Those are isolation mounts so I went to the local hardware store got 2 rubber stoppers and I will make them out of rubber and replace in the very near future.
And Not sure how I am going to deal with the counter shaft bracket....manual I ordered from Logan shows lathes after serial number 40115 to have (2) oiless bushings.....mine has none. Because of that the shaft is quite worn and will need replaced, but without the bushings it will repeat the failure. So off to work I go to bore out the bracket and install 2 bushings with grease fittings, as I am not comfortable with just oil there. Only have one more week off till I have to go back to work, looks like I won't get this up and running but going to push hard....
Till the next update...
