I'm building my own CNC Mill and I'm looking for some advice/experience regarding the Z Axis. I'm using a Fehlmann (Swiss made) X-Y table with ball screw conversion, but I'm fabricating my own Z Axis Column with Linear Rails and a double nut ball screw. The NEMA 34 stepper motor is mount at the top. I'm on a budget so I'm using conventional stepper motors and digital drivers, some of which I have left over from other projects. Ultimately, I'd like to upgrade to closed loop servos.
The Z Axis motion is nice and smooth, but as expected it will drift down when not powered. So, my question is should I use a power off brake or a counterbalance. I know Teknics sells a NEMA 34 brake but it's for 1/2" shafts and my motor is a14mm shaft. Does anyone know of a source for similar brakes.
Any help would be appreciated.
Jim
Jim
