Every once in a while I get a bug up my butt and I decide to do a shop project.
The original shop is a 12' x 20' chunk of my 30' x 40' garage. I just walled off the section and framed the outside wall then drywall to protect the insulation. I keep it around 40⁰ in the winter and warm it up when I need it.
This weekend I claimed the rest of the end section of my garage along with a 10 ft garage door. The new section had to be 15' wide to accommodate the garage door.
I used an interior grade primed door. I would have used an exterior door but they are near $400 and up. I hope it holds up okay.
This area will end up with benches for my bench grinders, arbor and hydraulic presses, welders, oxy acetylene torches. It will only be heated when I need to use the area. The garage door will be too hard to insulate well for maintaining temperature. No more freezing my fingers every time I need to clean up something on the wire wheel. Should heat up pretty quickly when needed.
I am horrible at drywall......just look at the outlets. Lol!
Ceiling drywall is going up next weekend.
The original shop door I built that is staying in place to keep the shop nice and toasty.
