- Mar 26, 2018
- 8,410
Details on the lathe please.285k on my 97 F250 HD 7.3L
Oh, and what I bought today....
Side note...I am pretty sure everything I have ordered for my new machines causes cancer in California. That place must be dangerous...
It sure is, don't ever come here. Not only cause it's dangerous but because you can't buy any of the good stuff, it's all banned. With all the things I've bought that causes cancer only here in Cali & for so long, I think I may have had cancer like 6 times already but I'm still alive .
(ok, gott go knock on some wood now)
Oh, and BTW, not ALL the good stuff is banned!
I mounted the adapter to the chuck after a good inspection and cleaning.I bought a 5C collet chuck from CDCO a while back. It's not that I haven't been able to make good parts with it, it's the poor fit up of the collets and the cam lock to the spindle.
I bought this 5C collet from Smalltoolsinc.com It's a TMX made in Poland.
I bought the, no machine, D1-6 cam lock as well.
The difference in quality is substantial. It locks up like my Bisons.
Twice the price but much less than the name brand chucks.
I'll try and sell the original I guess. It works fine, I'm just a freak.
The adapter locks up very nice. The cams are all pretty much within the 4:30 range and lock up smooth with no binding like I had with the Chinese chuck.
The runout with the Chinese 5C chuck (I had to machine the register between the adapter and the chuck) is about .002".
The runout with my new TMX is just over .005" at the 5C taper. I first checked runout at the 3/4" piece of tight tolerance tool steel. >.005"
There is no spec on the Smalltoolsinc. web site.
Have you had any luck trying to clock the D1-6 cams? for better results?
I've read where some guys cut the register .002-.003" loose to allow for adjustment with the 3 bolts.
Any ideas? I have emailed the tool supplier to see what they suggest.
Dang it.
I haven't indicated the chuck body. If it's the same as the 5C taper then the body has to move on the adapter.If I remember correctly there are six cams. Try rotating the chuck inserting the chuck into different cam mounting holes and see if it has an affect on the run out. If by clocking the chuck you find a better reading, then mark that alignment.
