Yep,,,, as well as tires are still using “American” rim sizes. I’m guessing they’re that way worldwide?????And yet most of the hydraulic system/hoses/fittings were still "standard" sae orb and jic fittings.
28.5mm? Nah. It'll never work.....My friend was describing what he wanted the other day, and said "make it 28 and a half millimeters long". I explained that metric doesn't have halfs. It doesn't, right?
I would bet that if one was to look at the old NASA prints that they are all metricOne nation has put a man on the Moon, and brought him back safely. The rest use the Metric system.
and they make inch scales in .1 and .5 and .100 graduations as well, starrett calls them aviations scales. Many drafting scales did as well. So what is your point?I'm not talking about a drawing. If I'm making a quick one off part and using a scale It's sometimes more convenient to divide metric by 2 instead of using fractions.
https://www.newscientist.com/article/dn17350-nasa-criticised-for-sticking-to-imperial-unitsI would bet that if one was to look at the old NASA prints that they are all metric
Why not, lot easier to remember that a F or 7 drill is needed. Every set I have has the decimal stamped under the letter/number size. Every manufacture will give a free tap/drill size posterVery true Mitch,
the problems I have are when numbers and letters are assigned to sizes such as threads and drills, are they really necessary? Decimal inches for drill sets would be a start, metric sets are usually 1mm to 10mm in 0.1mm (0.004") increments.
ISO standards use British Standard dimensions on water and hydraulic fitting in Europe, so those will be inch based until the standard gets changed, which will probably not be during any of our lifetimes.
I already made my point...twice. Maybe the 31st edition of the ENGLISH HANDBOOK will help.and they make inch scales in .1 and .5 and .100 graduations as well, starrett calls them aviations scales. Many drafting scales did as well. So what is your point?
But .1", .05" or .01" graduations are not a fractions and easy to divide by 2.I already made my point...twice. Maybe the 31st edition of the ENGLISH HANDBOOK will help.
They finally did but really, where did you even pull that from?
Yea, if I had a hundred dollars for every time I found someone had or were trying to use 1/8-27 npt in a G(erman)1/8 port?(which is 1/8-28 British Whitworth) If feels good/fine for 3 threads and starts getting stiff due to the thread difference, so people just put a wrench on it an tighten.
They actually make metric fittings/oring ports. Yet the japanse and germans are so invested in british whitworth threads for fluid fittings they won't change. Its hell to find tooling and fittings. Ironically Caterpillar has been changing over to them before all the european and japanese companies.
