- Oct 29, 2012
- 1,330
You don't need this second part. Or in other words the VFD is the means to turn the motor on and off.I need to have a means to turn on/off power to the VFD and a means to turn the motor on and off when the VFD is powered up.
There should not be any kind of switch between the VFD and the motor. Disconnecting the motor from the VFD while the VFD is powered up, can damage the VFD.
Since you only need FWD (no REV) then the answer could be as simple as routing the RUN signal through the E-Stop pushbutton of your new box (and don't use the on/off pushbuttons on the new box)
