- Nov 27, 2012
- 7,864
Will has a lot more experience running work hardening materials than I do and can give you better guidance.
Mike (Aukai), the things I mentioned earlier about locking cross slide, compound slide, compound slide orientation, lock nut on the knurling tool, etc may all come in to play when you start knurling that 304. You may not need to but start with those things if it gives you trouble. Be sure to keep the work cool as 304 will harden easily. Least amount of passes as possible. Attempting a full knurl in one or 2 passes will require a lot of force & is why the things above will help.
