- Jul 29, 2014
- 2,737
These questions are all old bromides that occur over and over. Now that you have been through these answers, you're all geniuses the next time the quiz comes along.
I got two of the three "official" answers, but I have a quibble about question #2. Consider this: suppose that the 5 widgets are the result of 5 SEQUENTIAL ops on those 5 machines. Then it would, indeed, take 100 minutes to make 100 of them. I looked at the question and saw ambiguity in the specification. The answer in the link fleshes things out by indicating that each machine is a "widget" machine, but, being a (partial) machinist, I also considered the more likely scenario that each machine only does a part of the required operations needed to make a widget.
So there.
If brains were gasoline, I wouldn't have enough to power an ants motor scooter around the inside circle of a Cheerio
One error, you used the diameter rather than the radius. Also, googling the diameter, I got 7,917.5 miles. but whose counting?
You are right. I went into the weeds and never came outI don't think it matters if the machines perform sequential operations, or if each machine manufactures complete widgets. The problem states that 5 machines can make 5 widgets in 5 minutes. 100 machines can be thought of as 20 groups of 5 machines. At the end of 5 minutes, each group will have made 5 widgets. 20 groups times 5 widgets per group equals 100 widgets in 5 minutes.
John
It certainly can cause hostility. I don't know why it should. It doesn't matter how you answer these questions.I also got all of the questions correct in only a few minutes. Used a pencil for the first one, but the last two were in the head almost instant.
BUT then, because I enjoyed the quiz, I started giving the test to family and friends. It did't work out well for me. None of my friends or family got more than one right and then they seemed to be offended when I told them I thought the questions were easy 8th grade level math. Stupid me.
