Sure. I was wondering why they did not show. Thanks for letting me know.Heic files are Apple specific, can you please change the file type? Can't view the pictures.
Thank you for the comment. My thoughts exactly. I did two test holes with the center drill, then drill and tap. I still have the imprecision. I had a grandson put a mower away and he hit the power feed on the end of the mill hard enough to knock it loose. That is one of the reasons I went back through the process of testing the alignment of the bed and vertical head. All seems correct. But now I have ordered a tramming tool to more precisely measure the alignment of the mill. We will eventually get it figured out.You should be able to re-center on the drilled hole. To avoid having to do that, If I am going to have to drill multiple holes (and not use the CNC capabilities), I dry to do all operations one hole at a time. Pilot; Drill; Tap. then move on to the next hole. This guarantees perfect alignment.
All good thoughts and ideas. I believe the mill is out of tram. I believe Blondihacks, among others, have covered in detail how to test and correct a mill's tram.If your problem was caused by knocking the mill out of tram the tilt should always have the same orientation.
Since you did each operation step on all of your mallet heads before moving on to the next op, it may be difficult to figure out how each head was installed in your vise, the most reliable way to check that theory out is to drill and tap a test piece and see how one of your handles looks when you screw it into the test piece.
If that is indeed the problem you may not need to re-make the heads. If it's flat, use the opposite side. The "bad" hole can be plugged with a short threaded piece that's glued in place then milled flat (after tram has been restored ) .
Measure the angle between one of your mallet heads and handle. It it's inconsistent with your tram measurements there's something else going on.
Good idea. I have an angle tool for doing just that. A few pictures are attached. The error in the verticle seems to be higher than indicated by my tram measurements. I seem to be seeing a 2° error in the verticle.Measure the angle between one of your mallet heads and handle. It it's inconsistent with your tram measurements there's something else going on.
If that's not accurate enough, another sanity check would be to install one of them in your vise and indicate off the handle as you raise the spindle.
