- May 2, 2021
- 330
EXT. Thanks. Makes sense. Did not have time to get to the machine today - but will provide this info.
The point may be moot though - if my tools won't drop out, I am probably going to have to have the spindle ground if I want automated operation. Let's see what results we get from your test. Should have at the weekend.
Thanks Jim.
What have you done with all your time?! .
I have it set up like so.
I then have a DC power supply turned to max (30V)
That goes to a DC motor controller:
I think there may be some value in considering the bigger picture at this point
My current thinking is :
- Upgrade manual capabilities - use this to learn with and improve my basic skills
- Cut he box that sticks out over the machine - off - completely.
- Remove the large box on the side - and re-mount to the wall. This will be much nicer to access, and allow the machine to push back 1.5'
At bare minimum - take the screen control box off and let some light in/ lower risk of cracking head open.
Let me know your thoughts regrind the current systems's flaws/ options for creating more grunt at low feed speeds for the spindle.
Thanks!
-CM
Thanks Jim.
Thanks!
-CM
