- Apr 24, 2021
- 462
I think so, but as others have said I think I would probably mess it up. Also, at what point is the amount of time I spend to do that costing me more than 180 dollars to bore it out? With my measurements, the block is just too big for my little lathe, even with the carriage removed. I like your thinking though.2 thoughts of which you likely have already thought of 1 and 2 is really a thought exercise:
1. looking at your pictures, where the plate unbolts to provide access to the internals of the block, could you fabricate a plate to bolt to that area which you could bolt to your carriage for work holding? If you removed your tail stock, could this plate be setup in such a manner as to give you more room to the head stock even if it required a rest back to the flat sections of the ways? with the tail stock out of the way from the end of the jaws on the chuck to the end of the bed is about 40"+/-.
2. There are several engines built much like the old VW bug with bolt on Jugs/Cylinders (air cooled) that can be had very reasonable. Design and fab your own block and use one of those possibly with the cylinder head made for the head to simplify and the guts from your engine... That would not seem a very long stretch, not to complex. A lot would depend upon the rules of the class you are racing in....
As for what you are saying about vw engines. I love the idea and like where you’re going with that. The problem is lack of a mill and many tools needed to fab a block like that. What were you thinking for fabricating the block? I wish that I could find a way to fab my own block. I guess if it were basically a square shape without cooling fins it could be done for sure, but I will have to investigate further. I didn’t realize vw had separate jugs. My goal is to make something gnarly fast as cheap as possible. I want the scariest and sketchiest acceleration, even if it’s on a go kart.
I also like the cleanliness and high hp level of this build and plan to copy it eventually once I learn more about these small vtwins and fabrication.
