- Aug 24, 2013
- 29
My son-in-law got what he though was a good deal on a toy. He tore the very worn 6 way dozer blade off it and called the local machine shop to give him an estimate on making pins and bushings for the blade and mounting fixtures. First bid was $6,000.00 and the second bid was $4500.00 which was more than what he paid for the dozer. So he packed up the machine and dropped it off at my place and said can you bail me out. All the pins are severely worn and the holes are egg shaped. The bushings that are still left are falling out of the bores.
So, I guess I have my first machining project and have many questions. I have a Colchester 15x48 round nose lathe and a J-head Bridgeport mill up and running.
Questions:
1. Local machine shop said they use 4140 steel to make pins and bushing because it is already heat treated but still machinable. Is this a good choice?
2. For a press fit how much oversize should the OD of the bushing be ?
3. How much undersize should the pin be to the ID of the bushing ?
Thanks for the help, many more questions to follow.
Questions:
