- Sep 11, 2013
- 115
You're welcome, Joe.
I think that bottom flange on the brackets where there seems to be a stub used for accurate installation would be a good reference surface to measure and establish the correct center location of the hole after you have bolted it to a rigid flat and straight surface.
I would assume the mating parts where they were originally bolted to in the machine were also in line, flat and at the same plane of reference, thus a rigid and straight flat surface to bolt them together temporarily during machining would be a sound setup.
Normally, in line boring is done while the parts are still installed to the original component as they should be, but in your case the components are already disassembled so there is a need to duplicate the relative location as accurately as possible by securing them to a flat straight surface.
I don't think the location of the bore has to be exactly dead on center withe reenforcing collar or exactly on the original spot as they were before, although that's surely preferable or desirable.
What's critically important is that the two pivot holes are in line as perfectly as possible, perpendicular/square with bracket movement and free to pivot at the same rotational axis center during operation.
